TwinTurbo.NET: Nissan 300ZX forum - Drain the tank so the leaks is stopped during the repair
Subject Drain the tank so the leaks is stopped during the repair
Posted by z32z on December 13, 2009 at 10:03 PM
  This message has been viewed 82 times.
In Reply To pin hole leak on bottom side of gas tank.... posted by GitNMyBelly on December 13, 2009 at 08:07 PM
Message At your local Home Depot, Lowes, or auto parts store you will find a apoxy made for fuel tank repairs. I have used several brands and they all seem to work well. Dont forget to rough the area up with sand paper prior to applying apoxy. JB Weld also works great. You may need to let the apoxy set for 10 to 15 minutes after mixing prior to applying. This will let it thicken so it wont dripp down.
